Hello,
Do you know the frequncies of electric guitar strings?
E A B D G E
....but do you know the frequency of each, i need to know so i can design the output filter of my class D electrc guitar amplifier
E A B D G E
The harmonics extend right up to 20KHz, though most guitar amplifier
speakers have a huge peak around 5KHz and then die away, so you'd
probably get way with a 10KHz filter, but not much lower, ideally higher.
rgds, sreten.
rgds, sreten.
Your filter frequency is more dependent on your switching frequency than anything else, but should obviously be higher than 20KHz to give full potential audio bandwidth.
It's your trade-off really. If the amp's going in a combo with a typical 12" guitar speaker that doesn't put out anything over 5kHz, then a -3dB point at say 10kHz will do fine and makes your filter design less demanding than choosing a higher corner frequency.
However, if it's a separate amp, and you might one day find yourself in a pinch, and wanting to use it say for makeshift PA, you'll be kicking yourself...
What is your switching frequency? If it's way higher than 20kHz, go for full audio bandwidth I say.
Choices, choices, choices......😀
I agree with the other posters but if your guitar speaker is like this :
A 10KHz filter is well good enough. FWIW the fundamental of the strings
of a guitar go from low E 82.5Hz to top E 330Hz, but that is irrelevant.
rgds, sreten.
rgds, sreten.
And don't forget the open string freqs are not the limits, guitarists often will play on the high E at the 15th fret.
high thanks, switching freq = 100KHz.
I am just wondering about putting a low freq speaker like above, and a high freq speaker in series with it.....to get those high freqs sounded out
- Live Sound
- Instruments and Amps
- Frequencies of electric guitar strings?
