The speakers are 4 way in great working condition. These are 4 way system designed for full range or biamplified operation w/ 18" woofers, 10" mids, 2" compression drivers & ultra high tweeters. These are very heavy and local pickup preferred but will ship but will ship depends on agreement.
Scheme: 4 ways, 4 loudspeaker bass-reflex scheme, and a floor type
Unit: For low-pass: 46cm cone type (2245H)
For inside low-pass: 25cm cone type (2122H)
For mid-high ranges: Horn type (2420+2307+2308)
For high regions: Ring type (2405)
Frequency characteristic: 32Hz-20kHz±3dB
Directivity (horizontal x vertical): 60 degrees x 30 degrees (-3dB, 16kHz)
Output sound pressure level: 95dB/W/m
Impedance: 8ohms
Allowable input: 120W (at the time of a network)
200W (multi-amplifier Lo)
100W (multi-amplifier Hi)
Cross over frequency: 320Hz, 1.3kHz, 10kHz (at the time of a network)
290Hz, 18dB / oct (at the time of multi-amplifier)
Enclosure dimension: 253L (Woofer)
14L (mid Woofer)
Dimensions: Width 765x height 1096x depth of 470mm
Weight: 112kg (at the time of an original packaging)
audiocraftlimited@gmail.com
Impedance: 8ohms
14L (mid Woofer)
Got any pics of the actual speakers? Using stock photos found on the web doesn't really give buyers a sense of what you are selling.
Index of /4345 didier/pssforum
Index of /
JBL 4345 refurbished
Index of /
