Two Metcal soldering irons, both in great condition and full working order. Both SOLD
MX-500P-21 with 13 spare tips, original nearly new MX-RM3E handpiece - plus iron stand and mains cable.
The power supply unit has been masked off and a tidy coat of matt paint applied. It is a very tidy job.
SOLD
SP-200 with 15 spare tips(3 new & unused) Replacement Thermaltronics hand piece and mains cable.
No iron stand unfortunately, unless a buyer for the MX-500 does not want the stand then it can go with this package.
SOLD
SOLD
SOLD
A quick check on the web will give you your answer but if I remember they are not.
I switched from a Weller iron to a Metcal, the older version of the MX-500 and it greatly improved my soldering skills.
Good deal on both these units.
BillWojo
BillWojo
Aha, couldn't see the differences on my phone. I was mulling that the only thing better than a metcal was two. Just checked and mine is an old PS2 but cannot find out what the xref was.
I use an old PS2, all the parts on the MX should interchange including the hand piece. Using one of these is like soldering with a pen, your fingers are very close to the tip and you have much better control than the old fashioned fire sticks.
BillWojo
BillWojo
I think the new PS-800/900 is the replacement of the SP-200 so the tips are the same SSC-XXX series.
The MX-500 is all you need Bill but certainly the tips are more expensive to replace, it uses the SSTC-XXX series tips.
Just checked and my tips are indeed STTC compatible. Thank you. Need to work out if I can justify this as its a real bargain.
