FS SONY Mobile ES CDX-C90 car audio receiver/tuner
High end Sony mobile ES car stereo, cd player, tuner
Removed a couple years ago from my car. Best car stereo I have ever owned and it pains me to sell it. Retailed for over $1200
Gently used, faceplate, faceplate box, remote included plus original box
For pictures email me or check out my c-list add
https://post.craigslist.org/manage/2641639816
This peerless CD player/tuner has four 20-bit Burr-Brown D/A converters for truly lifelike musical reproduction. But the big story here is Sony's analog preamp, which is capable of harnessing the full potential of the cutting-edge CD circuitry. For the first time, preamp functions are handled by a device with equal-to-CD specs, and you'll be awed by the CDX-C90's exceptional dynamic range. Simply activate the DVOL function (bypasses all circuits except volume control) and get ready for unparalleled audio clarity.
Since all CDs are recorded differently, and listening environments vary, the 4-position VC digital filter adjusts the oversampling method, optimizing imaging and dynamics disc by disc. To ensure that this superior audio technology is not compromised by simple skipping, Sony has built in Advanced Electronic Shock Protection. Three sets of 4-volt preamp outputs (including a subwoofer out with adjustable low-pass filter) provide flexibility for the required outboard amps, since none are built-in.
The sensitive SSIR-EX tuner is enhanced with Adaptive Reception, a feature that minimizes station-to-station interference by sensing adjacent-station interference and adjusting IF bandwidth accordingly. And not only does the receiver have a copper-shielded chassis, but the built-in preamp board is completely separate from the other internal components. That means no electrical interference.
The motorized, fold-down face offers a user-configurable full-dot matrix LCD for system status at-a-glance. The included RM-X90 driver's remote is equipped with the same Rotary Encoder as the receiver, allowing unprecedented ease of control from the steering wheel. This wired remote even detaches from its base, providing an extra measure of security. A wireless remote is also supplied for your passengers' convenience.
Details:
SSIR-EX tuner with Adaptive Reception
Custom File Plus programming (with optional CD changer)
3 sets of 4-volt preamp outputs
DVOL (Direct Volume) function for optimal signal-to-noise
Variable Coefficient (VC) digital filter
copper-plated chassis
separate internal preamp circuit board
wired and wireless remotes included
motorized fold-down panel with full-dot matrix LCD
separate amp(s) required
clock
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 109 dB
FM sensitivity 8 dBf
