FOR SALE for $100 including shipping to the USA lower 48. Ships in the original MFG packaging.
I am selling a new, never used Analog Devices ADAU1452MINIZ-ND full kit (board, PS, USB programming adapter). It currently lists for $225 at Digikey:
https://www.digikey.com/product-det...L-ADAU1452MINIZ/EVAL-ADAU1452MINIZ-ND/4571726
The board has SPDIF optical input and output, 4 analog inputs and 8 analog outputs and can be used as a powerful DSP audio crossover. The ADAU1452 is a more capable and newer sibling of the ADAU1701 used in miniDSP products and other DSP crossovers.
The Product Guide is found here - read this in detail for info about setup, specs, capabilities, etc.:
http://www.analog.com/media/en/technical-documentation/user-guides/EVAL-ADAU1452MINIZ_User_Guide.pdf
Configuration and programming of all DSP functions is done using the SigmaStudio environment that is available for download from AD. Details on the capabilities of SigmaStudio can be found on the product page:
SigmaStudio | Analog Devices
The DSP processing capabilities of the ADAU1452 go far beyond the capabilities offered by miniDSP gear and can take advantage of advanced DSP features like compression and limiting or adjust parameters using external controls connected to the board.
