Good day!
I'm not an experienced audio DIYer but I've done a few small projects in the past. I'm a hobby woodworker.
I'm looking to build and imitate the Artison LCR Dual Center system: LCR | Savant. For simplicity, though, I'd like to use full range drivers such as the Dayton Audio PS95/83 or the Peerless TC9FD, instead of a combination of mid-range and tweeter. Also, I want to install these on the wall, not on the TV.
My living room is 12ft x 15ft, and I sit about 8ft to 10ft from a 60" TV. TV is hung on the wall at eye level.
How many drivers per channel should I use for best result? What ohm rating for the drivers? How should the drivers be wired?
The speakers would be used in conjunction with an 8" subwoofer.
I'd really appreciate if someone could assist me with these questions!
Well then, you’re not really emulating the Savants - they are not what you’d call a minimalist design.
A few questions should be answered before any useful advice can be proffered.
You don’t mention how these will be powered - i.e. what source(s), signal processing and power will be used, and whether simple stereo and sub (2.1), or higher level of surround. Before proceeding much further, I should note that I’ve evolved my own HT system over the past 15yrs using FR drivers, and definitely have some strong opinions that some might consider to border on dogma, so consider the source. My room is approx twice the area you describe, and the listening position is about the same from the front row as you indicate. I’m also an unabashed advocate of multi-channel - including discrete centre channel - and multiple subs.
By “using (sic) in conjunction with an 8” subwoofer” can it be assumed that you mean a single separated powered unit with mono LFE channel signal derived from surround receiver/processor? If so, then in the fairly small room described, and with the crossover frequency from mains to sub set at, say 100Hz, you could probably get by quite nicely with a single competent FR driver per channel.
Personally, I’d be inclined towards at least the next size class up from the PS95 - say something like the PS100 or if budget allows, the PS180. My current set up is 7.1, with Alpair 10.3 across the front row (LCR), with different enclosure types for the mains and center. Previous FR speakers I’ve tried were Fostex FF125WK, 165WK, and Alpair 7.3. I’ve never heard any of the Daytons, but they get a lot of good press here, and while a lot of folks love them - particularly for line arrays- my only experience with the Peerless was “meh”.
The system is in a basement room whose layout / traffic pattern dictates that the screen and front row/height surrounds sit in front of a 9ft wide / 3ft tall window, with the electronics and center speaker on a low boy type stand with an integral upstand on which the TV is attached. This constrains size of enclosure for the centre. I’ve tried both discrete and phantom center with several different speaker types, and prefer the former. Other folks have the opposite experience.
More sage advice to follow, no doubt.
To answer your question about how the speakers will be powered, I'll simply be using my Marantz 5.1 AV receiver. My plan would eventually be to build rear speakers with the same drivers. What I like about the Savant / Artison speakers is that they still use the centre channel output from the receiver, but they're set up like a phantom center.
Using multiple drivers, if each run full range, will bring a lot of trouble, comb filtering and a very narrow vertical dispersion.
For myself, if I were to use 3" or 4" drivers, I'd go with the TABAQ design, hang them on the wall, the centre placed under the tv, and surrounds hung either behind or on the sides of the couch.
Paint them black to match the tv, of the color of the wall to blend them with the room.
Easy to build, and sounds wonderful. The PS95 would work in that design, but not the TC9.
I agree with Perceval up to a point. I’d build either the TABAQs and hang them upside down to get the driver closer to ear height or build Jim Griffin’s Small MLTL for Alpair 6 (Small MLTL for Mark Audio Alpair 6 Drivers) without the length of the false bottom, move the port to the front, and hang them upside down for the same reason as the TABAQs.
I wouldn’t bother with a center channel until I heard either one of these to see if they can generate a phantom center channel on their own. I realize neither one of these uses the drivers you mentioned. If you still want to pursue those then perhaps one of xrk971’s miniKarlsonators would work.
... the Artison LCR Dual Center system...
I’m guessing you ar egoing to need some DSP to properly deal with that array.
Something that looks wizzy but i would be skeptical of how well they work.
dave
Based on my recent 'adventures' in SOTA DSP, you really can make a 'silk purse out of a sow's ear', so I imagine there's a pretty nifty processor in each section driven by an equally impressive controller, but build it out of 'FR' drivers and it will need far more processing done right than the inexpensive DSP [most] folks here are using, so TTBOMK this is likely an exercise in futility.
A reasonable facsimile though is a variation I did for my first big screen TV in the early '80s with a derived 3rd channel that only added just enough speech range/amplitude to 'center' it on screen except of course now would be a discreet center channel.
The 'FR' drivers would be across the top, spread apart at the THX 60 deg [included] angle and angled down, toe'd in as required. The number of drivers required in each line array will be dependent on how loud they need to be capable of at low distortion. The CC might only need one or two since it's going to be just enough to fill any 'hole'/'softness' in the vocals.
GM
GM
OK, so while others have offered their own observations in the interim, I'll add more word salad to the buffet. I couldn't find much more detail on exactly how these are supposed to work than a brief description of a shitton of drivers (32 per pair) for 3 separate channels in 2 enclosures, providing a phantom centre channel by having a curved line array of small drivers on each side of the screen. Apparently you can get a patent for anything that nobody had heretofore found a need for, or bothered to make dated detailed drawing of.
All and all, these are not your grampa's wall mount speakers, and I'm still trying to decide if I think this is brilliant, or just marketing BS. One would need to hear them for themselves to reach a conclusion.
As you've indicated the use of a "proper" surround receiver, of which most modern models should have sufficient DSP facilities for the task, I think the main question to address would be how to most expeditiously and affordably emulate this design.
From what I can deduce from the description and photos of the LCR, the minimum way to do so would be a total of two FR drivers per enclosure in isolated compartments - one for each of the L&R channels, and the second run in tandem with the other channel to provide the phantom centre.
I'd still be inclined to use a larger driver for the L&R, but perhaps a pair of smaller drivers for the centre pair would suffice. Where things get interesting is that many surround receivers are rated for 6ohms or higher when actually powering multiple channels, so it might be prudent to wire the phantom centre pair in series to provide a safer load for the amp. The receiver's auto calibration function should easily deal with sensitivity differences, and many models ost allow for drilling down further in the speaker set up menus to fine tune XO frequencies, level adjustments, and perhaps even EQ by ear. My last 2 Denons , current Onkyo and daughter's Marantz certainly do, as did my sister's old Marantz before it died.
The other concern I'd have is that based on several of my own builds, very shallow enclosures as might be most suitable for wall mounting can have issues with colorations from early reflections off back wall through the lighter weight cones that are often found in smaller FR drivers, which raises the question of the distance from the front of the screen to the wall - it's presumed you want the front of enclosures flush with the screen. Many modern flat screens are amazingly skinny, and unless you're using an articulating mounting bracket that allows for adjustment of all three angles - depth from wall, up/down tilt, and splaying from side to side - that distance might be only a very few inches. My sister has a 70 or so inch Sony on a fully articulating bracket which can be pulled out sufficiently from the wall to achieve almost 20dg of splay to either side - something she actually uses occasionally when in the kitchen of an open floor plan great room.
Don’t forget the A10PeN tat preceded the A10.3eN (and he also tried the A11ms (stock).
dave
That Dayton looks to be in the same family as the 8” point source, i have heard it (EnABLed), and it seems to have great potential. But will struggle to get low enuff to reach your woofers, and may not provide sufficient volume capability.
A larger driver might be more appropriate.
I am not a big fan of Dayton (PEs house brand), nothing to do with the quality of the product.
The TC9 is trash AFAIC. I bought 4, was very dissapointed, have managed to give away 2 of them in 3 years.
dave
chrisb, planet10, and others, I appreciate your comments.
I'm debating now whether I should proceed with the full DIY project with the FR drivers, or simply buy a pair of used Artison Skecth LCR on ebay and build custom wall-mountable enclosures. Buying used and building the enclosure will allow me to utilize the internal electronic components of an already-tested system. But the full DIY project is more rewarding... if it works out.
I must say that researching full range drivers has become a little frustrating at times. It's almost as though the specs and graphs only give part of the equation; the other part being how they actually sound in person. And that, I simply can't do without buying, unfortunately.
...as though the specs and graphs only give part of the equation...
That is the case with all drivers, it is just that FR drivers are harder to get right.
dave
If there are more than one model of LCR speakers in the Artison line, note that if the one you linked to earlier is the same as currently shown on their website that it includes an angled side firing tweeter that as I mentioned above is assumed to be connected to the two pairs of mid-woofers in an rather interesting MTM arrangement. If you’re intending to build a cabinet for these, or even mount them in wall, you’ll need to ensure output from those tweeters is not blocked.
Of course, I’ve not purchased a commercially built loudspeaker for over 20 years, and would still be inclined to build something. If you’re lucky enough to have a full wall available for both the TV and speakers; a luxury not available in my case, something much simpler than the 16 drivers per side - if I read the spec correctly - would be relatively simple. And to repeat what I’d posted above, I’d consider FR drivers to be a very good candidate for small room multichannel system. I’ve been quite happy with the results of such for at least 10yrs, and my room is rather larger than yours (i.e. 340sq ft)
I can envision (starting with*) something as simple as two 4” or so FR drivers per enclosure.
*spoiler alert, for some folks DIY speaker building is kinda like that old Mark Messier potato chip commercial - “betcha can’t eat just one”.
- Full Range
- Full Range Driver in LCR Dual Center
