This is a group buy for the purchase of the second generation Salas Shunt High Voltage Regulator.
It's a newer design that Salas did, with CRT brilliant layout work and a bunch of us prototyped over the holiday season. We had a zero percent failure rate of setups amongst us. (Which I consider great, as most of my work , well needs work)
Let's get to the point.
The board is $15 USD.
Mini-Kits will be available. The cost is higher than I wanted them to be - so I split them in two.
Again a disclaimer - this is the most dangerous product I have shipped yet. Failure to respect the high voltage of the product can have deadly consequences. This is not a beginners project!
The full specifications are in the PDF file. (attached as zip)
The google spreadsheet needs to be completed with your username and includes paypal payment details. Please don't post that address here.
Transistor Minikit 13 USD
1-Toshiba 2SK117's unmatched
3-Vishay 12V .5W Zener
2-20ma Red LED's
2-Supertex DN2540
1-IRF840
2-Fairchild KSA1381ETSU
2-TO-220 Mica Insulator
2-Keystone plastic washers
Resistor Minikit 9 USD
2- Dale CPF2 100ppm 68.1k
1-KOA M/F 1/4W 100ppm 1.82R
1-3296Y Bourns 1/2W 100ppm 200R
1-T93YA Bourns trimmer - 1/2W 100ppm 1K
3-Vishay Bayershlag 50ppm 100R
1-271 Series Xicon 1/4W 50ppm 10R
1-271 Series Xicon 1/4W 50ppm 1.8k
1-271 Series Xicon 1/4W 50ppm 470R
1-271 Series Xicon 1/4W 50ppm 220R
SSHV2 FULL KIT - Does not include board (And no BIG heatsink for IRF840)
$45
2-20ma Red LED's
2-Supertex DN2540
1-IRF840PBF
3-12v 1/2W Zener
2-Keystone plastic washers (above is transistor kit)
1-271 Series Xicon 1/4W 50ppm 220R (above to 68K resistor kit)
1-Molex 4P Fixed Terminal Block Black
1-TE Connectivity 2P Terminal Block
2-274-1AB Wakefield TO-220 Heatsink
1-647-10ABP Wakefield TO-220 Heatsink
1-Wima 10uf MKP4 1100v
1-Wima .33uf MKP10 630v
![img_05841.jpg](https://origin.dastatic.com/forums/gallery/data/1746/medium/img_05841.jpg)
![SSHv2Works.jpg](https://origin.dastatic.com/forums/gallery/data/1746/medium/SSHv2Works.jpg)
2-20ma Red LED's
2-Supertex DN2540
1-IRF840
$45
2-20ma Red LED's
2-Supertex DN2540
1-IRF840PBF
3-12v 1/2W Zener
I`m up for three boards.
Please sign up on the spreadsheet then.
It is now linked in my signature.
Hi Tea-Bag.
I'm interested in 6 boards with both parts options included. Would shipping to Australia (post code 3175) be possible? If so, how much should I pay for shipping?
Many thanks,
Tani.
8 dollars fixed shipping.
Mike
I would like to purchase the following
2) SSHV2 Boards $24.00
2) Transistor Kits $20.00
2) Resistor Kits $16.00
shipping $6.00
Total $66.00
Thanks,
Joe
PM Sent to Burned Fingers
- Group Buys
- GB for Salas SSHV2 regulator
