GL7815 regulator replacement with same pinout
@steveu: you are right but this is not something I am going to do rightnow...
@V4lvelover:
LM340T-15 looks good and pinout is the same than the 7805 : IGO.
For the 7805 (positive +5V), the datasheet says that the LM340A-50 has a better regulation, so good news.
I am still trying to find something better than the LM2990T to replace the 7905 (negative -5V), but it seems that the LM340A does not exist in a negative version.
Do you have any recommandation for a better 7905 replacement with the same pinout than the 7905 ??
and same question for the 7905 (negative -15V) ?
@altec9440:
LM340 positive serie, LM320 negative tension.
Are you sure: I went to the Mouser website, and the "LM320" search returns regulators that are not what we are looking for:
https://www.mouser.fr/Semiconductors/Power-Management-ICs/Voltage-Regulators-Voltage-Controllers/Switching-Voltage-Regulators/_/N-668jt?Keyword=LM320&FS=True
It would be a dream to find the equivalent of the LM340A but with a negative voltage ! exactly what I am looking for...
@v4lve lover:
The L7915ACV would be a good choice (the output tolerance is 2%) but unfortunately the pinout is not compatible with the 7915...
Edit: my error: it seems that the L7915ACV is pinout compatible with the 7915: GIO...
@altec9440:
Resultats de la recherche pour : LM320 Texas Instruments Regulateurs de tension de commutation – Mouser France
LM78xx positive / LM79xx negative
LM340 (c) xx positive / LM320 (c) xx negative (where case is T for TO220, K for T03...). Precision types was LM140/LM120.
lm320T-15 from mouser
L7915 STM from electrodif
"A" have a narrow regulation but useless for near almost uses.
a good ressource :
NSC
Hi all,
I have finally ordered:
  • LM340A for replacing the 7805
  • L7905ACV for replacing the 7905
  • LM340T-15 for replacing the 7815
  • L7915ACV for replacing the 7915
These should bring significantly better regulation than the original ones.
Provided that they are used in a bass dedicated amp in a bi-amplified system, I am not sure it would make a sound improvement to invest more money than these.
I often use the TEKDevice regulators based on the TPS7A47 exceptional chip, when they are critical, but they support only 1A...
