Something i feel this section is lacking, is a good list of good transistors for use in amplifier output stages.
I begin with a few i think are decently cheap and still pretty good:
2N3716/2N3792 (assuming these are still made)
2N3772
2N3773
TIP35/36C
BD911/912
2N3772
2N3773
TIP35/36C
BD911/912
NJW0302;0281 are barely more than usd $2. each, in USA
Extraordinary PNP-NPN match & gain linearity to 2.5 amp. pair them up, &
resultant amp has enough power to blow up your speakers 3X
Doug
Doug
I have had very good service from irfp240/9240.
Despite being switching transistors they produce a very good sound.
Posted by Tekko
2N3772
2N3773
TIP35/36C
BD911/912
Hi, These are probably obsolete but of course you may get NOS.
I have tried BD911/912...did not sound great.Better to use MJ15034
if you can still find them.There is the all time favourite 2SC5200 and
the current version made by ON semiconductor.
There's the old MJ15003/4 and MJ15024/5. Still available, still usable.
MJ(L) 21193/4 for something a bit more modern.
Then the modern Onsemi transistors such as the 3281/1302 variants. Fairchild have their own 2SA1943/2SC5200 clones in several packages. ST also have the same.
I barely dare to buy anything else than BD911/912, TIP35/36C, 2N2955/3055 and similar due to all the fakery around the ones mentioned.
I agree on the IRFP240-250 beeing a decent audio output transistor, im using the 500V version IRFP450 with good success and good sound.
2N3772
2N3773
TIP35/36C
BD911/912
check out this thread:
http://www.diyaudio.com/forums/soli...istor-families-audio-power-output-stages.html
- good output transistors for amplifiers ?
