Who can upload a schematic of this pre-pre ?
A slight popping is audible without playing a record - dependent of the position of power supply lead (connection cable) to the pre-pre.
Thank you very much.
Graham Slee Projects Era Gold Phono Stage and Elevator EXP Step-Up [English]
Graham Slee Elevator EXP Pre Amplifier - Analogue Seduction
era gold mkv graham slee + elevator mk III mc - DISQUANTIQUE
MachOne classics - einfach Stereo! | Graham Slee ELEVATOR EXP
Graham Slee Elevator EXP Pre Preamplifier 2xAD829-OP249.JPG41.9 KB · Views: 486
Graham Slee Elevator EXP Pre Preamplifier rear-panel.jpg73.1 KB · Views: 396
Sounds like slight instability or RF pick up --not surprising when a bandwidth of more than 50MHz is spec for those two video chips .
A "cure " using small value ceramic capacitors might help as you would in a repair to a HF communications receiver.
Matter of fact bandwidth can be increased to 95MHz (-3db) .
At those frequencies even very small faults are amplified.
This is also from my view the reason.
But unfortunately without schematic I haven't a possibility to help a friend (which isn't able to create the circuit diagram with help of the PCB's) and send him the appropriate instructions.
I cant find any schematics of his products but you could try his forum -
Graham Slee Audio Forum | HiFi System Components
or contact him.
or contact him.
