Graph Grabber data conversion.
Hi jdh,
GraphGrabber csv file is only two columns per trace. You need 3 columns for .frd and .zma files for Xsim. Also no header text for the first row.
Edit the csv file from GraphGrabber in a spreadsheet.
Delete the first header row.
Add a 3rd column. If no phase data then fill it with zero's.
Save as csv or txt file.
Edit the file extensions to .frd or .zma
A help file is attached for using Graph Grabber for anyone getting started. Let me know if there are any problems with using it. It's so easy to be tripped up on some seemingly trivial step in this long process. I have used it for capturing MOSFET plots for use in LTspice Tables for VDMOS model extraction
Why don't you all use VituixCAD SPL Trace which saves directly with 3rd column as minimum phase? Or is there some actual problem or limit or difficulty other than Windows - or just protest against my continuous discount of response tracing?
