Harman Kardon citation 16 Issues
Hi there!
I have a citation 16 with huuuuuge problem it seems. Picked it up cheep. And works che thereafter unfortunately
first the usual problems with these amps it seems. The variable resistors were bad. Replaced them and recapped the hole machine, But after it seems that I shortened an output transistor 😑 it is at least my suspicion because I have around 30 volt on the output rails 🥺???? And cannot change the idle on Channel A
channel B is another story. There I can change the idle current. Problem is that as hotter it gets. The lower the idle current is!!?. Why is that? And soon as I cool the heatsink on channel B, let’s say I just blow on it a little, the idle current rises?!? Is it the emitter resistors they gone bad? And they change value with temperature ?
Another suspect is the IC/Opamp ua739pc…. Wherever I read about the Citation 16 it seems that these ICs seems bad. Anyone here that have successfully replaced them? Or know where one can get original?
Thanks!
Moderator
Joined 2011
First evaluate and diagnose, then repair. Shotgunning seldom works out very well.
Variac, dim bulb tester, or current limiting lab supply all can help initial start up testing.
Then check in-circuit PN junctions and electrolytic capacitors.
The soldering iron should not be used until you have a pretty good idea of the problem(s).
  • hfe_harman_kardon_citation_16_service.pdf
Reactions: 1 user
Yes, certainly measure in-circuit the emitter resistors as well. They dissipate more power than the other resistors do.
Sometimes their heat can even damage their own solder joints or the pcb underneath.
You can find bad parts most efficiently by the process of deduction from the observed and measured symptoms.
That's how these threads can be most helpful, to facilitate this process. Replacing parts en masse to avoid this
process can cause even more, and more serious, problems.
Until the 739 is proven to actually have a problem, it should be assumed ok. They are available surplus, if needed. https://www.westfloridacomponents.com/T581PF01/UA739DC+Dual+Op+Amp+Ceramic+IC+Fairchild®+UA739.html
Such a complex design can oscillate and/or exhibit high DC output offset in case of certain parts failure or degrading.
Reactions: 2 users
