HD-15 Kick Bin Horn Design
I am in possession of an unknown, unloaded speaker cabinet and an Eminence Delta-15LFC driver.
https://www.adamhall.com/shop/bm-en/archiv/2510/delta-15-lfc
The internal measurements of the said enclosure box are very similar in dimension to the outside measurements of a HD-15
Outside dimensions of a HD-15 - 578 x 578 x 472
Inside dimensions of 16mm MDF donor cab - 580 x 510 x 480
Most measurements are close enough but I want to make the horn longer and with a different radius.
I sketched out a quick box and horn with a radius of 500mm...... Attached below
Will this suffice....? Am I on the right track here.....?
I also read that I can reduce the volume of the driver chamber to make things a little more efficient.
Something like this
Correct; in theory and practice with compression horns you ideally want to reactance annul the horn, so near enough is to tune the rear chamber to the mean between the throat, terminus frequency, but a kick bin's terminus can be a variable depending on where in pi space it's located and/or whether stacked in an array, so if not much trouble, suggest trying it vs stock, which will roll it off higher with a 'faster' slope order.
If you make it more efficient, in the same sized cabinet, you will loose low end. Shorter horn: Less low end, smaller chamber: Less low end.
The Delta 15LF has T/S-parameters that suggest a BIIIIG rear chamber (highish Vas and high Qes), drivers with low Qes (around 0.2 - 0.25) will better suite the smaller chamber.
Reactions: freddi
