help...drilled hole too big
I inadvertantly drilled my heatsink with too large a bit. I found some aluminum sleeves at home depot that fit perfectly to shrink the size adequately enough to tap.
My question is how should I make sure they stay in there. They fit in snug by themselves. Can I use superglue? Or should I use epoxy. Epoxy might be messy because the sleeves fit pretty snug and most of the epoxy will end up being sqeezed out.
You might use superglue, but I'm not sure it will hold in a long run. Remember that when things get hot, the stress might break the glue bond.
If it's for an output device, one option could be going to the next size, tapping the hole properly and if necessary enlarging the hole in a device as well. This is the most appropriate fix. After all this is what is done in aviation as well, when somebody drills a hole too big.😉
Or insert the screw from the other side and use a nut if possible. There are also threaded inserts, which can be screwed in a bigger hole and are already tapped. What is the thread size?
I don't know how your setup is, but isn't the simplest solution (and therefore the best, no?) to just make a hole next to your original hole? Or can you not move your device. I broke a tapping bit in a hole, and it was impossible to get out, so I just made a new hole slightly to the side of the original hole.
I gather from your comment on "tapping" the sleeve that this is for a threaded metal screw to mount the FETs.
Best solution if you must use the same hole is to buy some "Helicoils" of the appropriate size.
These are a commercial product designed to fix your exact problem (actually designed for when you strip the existing thread).
http://www.hillcliff-tools.com/helicoil.html
You find a helicoil with the internal thread dimensions for your mounting screw. The coil will have a defined outer thread size which you then tap into the aluminium block, then insert the coil into the thread, then mount the screw.
I'll bet any money you like Boeing have used these before 😉
Mark
Now I remeber that product and if not me, somebody else I knew, was using it. If enlarging hole isn't possible this is indeed the best solution, although sometimes it's not practical waiting few days for the part to arrive in mail.😉
On the aircrafts, if it's not production but maintanance, the usual problem is with removing screws, as when they get older and the same are being used on and on, the slots become worn out and the screwdriver bit begins to slip. The only way is to either drill out the head or use easy-out. Next problem is when easy-out breaks and then high speed grinder with a special rotary file is used. But even then things may go wrong.😉 Fixing worn out or broken threads is not a big problem, since nothing is tapped directly in aluminum and special anchor plates are always used and it's usually a matter of replacing such plate (which is riveted).
You might consider using JB Metal Weld.
I would simply tap the hole the next larger size then fill it with JB. Then just redrill it the correct size and tap it.
The purpose behind tapping it the next larger size is so the epoxy has a decent surface to "bite" into. The threads will prevent the plug from pulling out of the hole over time. I don't think it would be a problem either way because you're really not loading it too much, but this way you know for sure that it will hold up to the thermal cycling... It's good to 300oC so I think you'll be safe... It's simply specialized epoxy with metal powder mixed it. Once it's set, it drills/taps/files just like metal.
http://www.jbweld.co.uk/files/prodb.html
You can get JB Metal Weld at almost any hardware store or Home Depot, Lowes, etc... The stuff really works!
I also found this interesting use for it on the overclockers forum for PC CPUs... It could be a cool way to attach output devices in an amp (as long as you're using a proven design)...
http://www.overclockers.com/tips169/
Good Luck,
I'd upload a picture but I just had to reformat my drive and I'm not quite to the point of reloading camera software.
I'm building the AKSA 55W amp. It's a normal looking heatsink that has a shelf to mount devices. The heatsink will make up most of the back of my enclosure which is a cabinet from the sixties that you slide the component into.
Anyway, I drilled holes from the back that exited between the fins. The hole's diameter is equal to the fin spacing. This eliminates the possibility of using a nut unless I use a screw at least 3" long to clear the end of the fins. I thought of that. I also considered repositioning the holes but I didn't want to risk screwing up again and ending up with a swiss cheese heatsink.
I went ahead and pressed the sleeves in with some superglue. Two of them tapped great but one is slipping probably from WD40 residue from when I drilled it. So what I will probably do is use some plastic inserts like they use for running screws into concrete and use a self-tapping screw into that. Won't be pretty but since the heatsink is on the back, I won't tell anyone if you won't.
Metal work is so emotionally trying.:bawling:
I thought about tapping up but I am using a tap that came with a hotstart kit for my dirtbike. Home Depot happened to be out of the next size tap and I decided that was for the better. My garage is filling up with tools so quick, I can't find places to put them and I don't think I would ever use that size again. I picked my hardware to match the 6mm tap that I had just to see how frugal I could be.
I also didn't want to hog the hole out any larger because the hole comes out between the heatsink fins and a larger drill bit in my kit would be 3/8 which would be way to large.
But thanks for all the advice.
If the hole is the size of spacing between the fins, why not trim the head of a screw so it fits between. The remaining part (forming T) will still be strong enough to hold it. It would be much better solution than everything mentioned so far.
Good luck.
Yep, tons of fun. Right now I'm working on building a wood lathe 😱 and I've hit a wall drilling a 3/4" hole through a block of aluminum.. well enough of my problems.
Helicoils are what I hear on rec.crafts.metalworking. You can also get them (or a competitor, Idunno) in rivet form, but it requires a special tool to insert them I think.
What I'd do is JB-Weld the hole full. Sleeve or not, if you're going to use glue you'll have to degrease it, some 1,1,1 trichloroethane works great but that's not very common 😉 😉 so acetone will work.
BTW, are you using 6-32 taps? Damn things are the devil's work I hear... step up (or down) to an adjecent size to keep from going through so many taps. If you can't, well, it sucks to be you. :devily: At least back it up often to break the chip, and back it out all the way if you have to, to clear the chips from the flutes.
Pete, I like that idea (although it leaves a nut on the device, doesn't look as nice 😉 ).
Tim
To jasoni-to others
The to18's I've seen are fine with a larger hole. (although the "slop" you get with a smaller bolt is useful)
In order not to bee too brutal about it, I ran the 6-32 tap into the semi. Then cleaned off the threads with a small file.
Since I was looking at a green-body toshiba, I could tell it was only case material coming off. I could then mount the Trans with a 6-32. (?!!)
Mcmaster carr sells 4-40 (internal thread)inserts.
I don't know what the outer pitch is but that would fix a hole that was quite a bit too big.
