I have brought this topic over to here as it's the most logical section for it - I started the post here: http://www.diyaudio.com/forums/showthread.php?postid=1526060#post1526060
What I'm trying to do is disconnect the bottom of the schematic that supplies the main VDD (10 to 40V) & some other supplies +- 15V +-5V.
I can supply the main VDD from 24V battery & the improvement in sound is huge compared to SMPS VDD.
So I wondered would there be an improvement if I also used the battery to supply the PS to the digital ICs? I can run it for about 2-3mins off battery & it seems to be much cleaner, clearer sound but not enough time for a real evaluation.
Here's my dilemma:
When I disconnect this part of the circuit & plug in a 24V DC from SLA Battery into the red line that gives VDD & thse other supplies, I get an error message of DCDect being 0V instead of 5V.
When I leave it connected in but break the red line connection to VDD & the +-15V & +-5V and instead feed the 24V DC into the red line, I get the switching IC (IC701) beginning to click after a short while at which point I turn off the amp.
I know I could fool the circuit by putting 5V on the DCdet line but I would feel safer if I knew why the DCDET is not being set to 5V correctly with my battery connection.
The schematic comes in 3 parts, the first one I've attached (Part 1) - it is the main switcher which supplies VDD & goes on to supply +-15V and +-5V on next schematic. This schematic (Part 1) also has a standby circuit, at the top and the main VDD switcher is complicated by the fact that is is a variable voltage volume control - controlled by a reference voltage which comes from the volume control. The +-Sense signal & the volcnt signal are part of this control loop.
Here's my dilemma:
Any change in sound is likely to be produced by the much higher AC output impedance of batteries and long external wirings in comparison with a well regulated SMPS. That kind of digital amplifiers exhibit 0dB PSRR.
Add some impedance in series with the speakers, maybe with non-linear elements to simulate the exponential/logarithmic I/V characteristic of batteries and you will get a similar result...
Eva,
I am saying that the sound with batteries supplying the main VDD i.e. the output stage is far superior to using the "well regulated SMPS" - it has more detail & nuances in the sonic reproduction & is quieter - more of the emotion of the piece is conveyed.
From what you're saying, I gather you're not a fan of batteries and seem to have a rigid stance about this? I can tell you, in this instance, the batteries are superior by a long ways. Maybe it's the quality of the SMPS - it improved when I put a large cap between it & the output stage
Now can we not get into an argument over battery Vs SMPS - I just wanted to find out how to bypass this complicated SMPS.
I discovered that the DCDET signal is actually generated by a microprocessor (which is powered on by the standby PS), so it is based on the timing of the supplies coming up. But this should be exactly the same as if I was powering it from the SMPS?
