Help needed to make wireless subwoofer
I want to convert my wired DIY subwoofer to wireless subwoofer. Now it is connected to my main system with 8 feet long audio cable, I want to convert it to wireless. Can any one suggest a bluetooth transmitter and receiver pair for this? Transmitter board will be placed inside my main system and the receiver inside the sub. They must be per-paired or something like that so every time I power them on, they will get connected automatically.
SUB: Pyle PLPW8D, IRS2092S 500W Mono amp.
Thanks in advance.
It will probably sound terrible. Bluetooth transmission speed is comparatively slow. Unless you have a facility to introduce a delay to your mains it will all be out of sync.
The SVS Soundpath latency is <14ms, the tri-band <19ms, comparatively fast for Bluetooth, but still the equivalent of one full cycle at ~71Hz or 53Hz. It is the same effect as moving the sub 4 or 5 meters (12.4 or 16.8 feet) behind the mains.
A delay of <19ms probably won't be heard as a synchronization issue if the sub is crossed below 100Hz, but will diminish it's perceived impact and cause some peaks and dips in the crossover range.
