Hello! I have a Logitech Z5500, and I really like it, but recently it started having an issue. The Pod is getting very hot at the back, reaching around 70 degrees. The component that's overheating is the one marked in the photo, and this causes the Pod's display to stop showing descriptions, leaving it blank. When this happens, I just leave it turned off for a while, and the display starts working again.
I’d like to replace this part myself. I know it’s a voltage regulator, but I don’t know the correct specifications to make the replacement. Could someone tell me the exact model?
If anyone has experienced this or something similar and knows of a solution, I’d really appreciate the help. Thank you!
