i work on a hifonics brutus bxi 4000D class D amp.all of the power supply fets were shorted.
i replaced them all but the amp wont power up because there are no 12V on pin 12 of the 494 ic.when i solder a bridge from the remote terminal to pin 12,the amp powers up and has an idle current of 2,5A.the high-and lowside signals at the gates of the amp-fets are present.
but the speaker relays dont engage.
all of the 5 transistors which are visible in front of the power supply board,are ok
where can the error be?
Check the remote line, to see where the fault may be. it can be an adjacent transistor near the vertical card.
Please, post a photo of the vertical card.
- General Interest
- Car Audio
- Hifonics Brutus amp does not power up
