High efficiency subwoofer
Hi all, I need to know where I can buy or at least some names of high efficiency (high sensitivity, above 98dB) woofers for my car. Anything in between 10 and 15 inches. Frequency responce should be as low as 29 at least. I would also Like to know why most car audio subwoofers are crap (87dB, WTF are you thinking boss?) The best I could find where gw-15xp at 100 dB's.
Basic physics.
Higher efficiency means less bass or a bigger box.
98dB down to 30Hz needs a massive box.
All that matters for subwoofers is basically volume displacement,
Sd x excursion and having the power to use it.
Any response can be EQ'd within excursion and power limits.
FWIW 87dB / 4 ohms = 84dB / real watt.
🙂/sreten.
Example:
Getting 102dB/W outdoors at 40Hz with a single 15 inch driver requires a 550 liter enclosure (folded horn).
Thighs are easier inside cars because cabin gain bosts efficiency by 12dB/oct below 60Hz and down to 20Hz or so. You can expect another 6dB or so of boost below 200Hz due to the inherent 0.5 pi spatial load.
I recommend 6th order bandpass boxes as they may be tuned to increase efficiency while equalizing cabin gain and keeping cone displacement under control. They allow some low efficiency drivers to sound loud with not that much power.
hawkeyefile said:
no, it moves 185 liters of air. and it only needs 60 watts to rattle the crap ou of the car.
185 litres is Vas, which indicates with Qts the sort of box you need.
99dB/W when wired as 2 ohm in reality is around 93dB.
The same as when they are wired in series.
Whichever way you look at the specs its not really a subwoofer.
🙂/sreten.
view pdf
15269 / CAT NO - 1844
• santoprene rubber surround
• extra thick treated paper cone
• diameter: 15.187"
• impedance: 8 Ù
• ...more info
PRICE : $ 103.99/ea. QTY.
djk said:
view pdf
� santoprene rubber surround
� extra thick treated paper cone
� diameter: 15.187"
� impedance: 8 Ù
� ...more info
Those are 94dB not 103dB
