Holton Amplifiers on Special!!
I have two power amplifiers on offer.
Holton Five-Zero-Zero Supreme Power Amplifier
Five-Zero-Zero Supreme Ex-Demo for $7600.00AUD...
As New Condition 10:10
Holton Five-Zero-Zero Supreme Specifications
300 Watts RMS continuous sine wave into 8 Ω
500 Watts RMS continuous sine wave into 4 Ω
800 Watts RMS continuous sine wave into 2 Ω
Biased into Class A/B
Power Bandwidth 3.5hz to 250khz -3dB
Dampening Factor At 100hz 8Ω = 1300
RCA Single ended Input impedance 20kΩ
Differential Input Impedance = 40kΩ
Single Ended Input Gain = 30.6dB
Differential Input Gain = 33.8dB
Fully Balanced Circuit Topology
SNR -110dB
THD-N = 0.005% @ 10 watts 8 Ohms
Unconditionally Stable into any load from 2 ohm loads and up
High powered Solid State output relays for silent turn on/off
and lightning fast loudspeaker protection
Extra Heavy Duty Two ounce copper gold plated printed circuit boards
Rugged Dual Die Lateral MOSFET Output Stage (2Kw Output Stage)
Total of 300,000uf supply storage
Almost no internal cabling; both channels are embedded into a single PCB
Holton NC502 Class D Power Amplifier
I have one only Holton NCORE NC502 Power Amplifier for sale; normally priced at $2395.00AUD on sale for $1749.00AUD
Specs
Class D Topology NCore
Power (2Ω) 2X 450W (not for use in BTL)
Power (4Ω) 2x 500W (1x 1000W in BTL)
Power (8Ω) 2x 350W (1x 1200W in BTL)
Channels 2
Weight 8kg
Chassis Dimensions mm 270W*320D*85H Including AL Feet
Mains voltage input 230V / 115V
Automatic input voltage selection Yes
