How do I build a subwoofer cross-over ???
hello.
I got my hands on a car amp.doesen`t have any bass bost, lpf etc.
only rca-input know from 400mv to 4 V
and a dyn gain knob max-min.
so i thought that I could get some tips on how to do a sub cross-over.
better still if I can make it with lest say 3 various levels...(ex. 400 hz- 600hz - 1000 hz something like this.)
It`s a 2 channel amplifier with bridged option.
I`m thinking that if I get tips one how to build one i`ll build 2 of them (for each channel).
I am sorry if I post in the wrong section.
Thank you and lets hope i`ll get this sorted out.
A 6dB per octave crossover would just use a coil of the appropiate value, as linked by carshateme above. However, bass frequencies are much lower than 400Hz-thats midbass territory, you want to be looking at freqs of 100Hz and down. Also coils aren't used commonly for sub crossovers in car audio(power handling and cost/lack of adjustability)-you may be better off using an active crossover, most stereos over £100 will have HPF and LPF filters built into them now days.
thnx a lot.
Got all the info I needed.Run once in the past with the same type of problem.forgot the websites doh....any how...
thx a lot for posting! once again this forum (for wich i am a newcommer) gave me up to date and speedy answers.
cheers to all of you and diyaudi...nr 1
thnx a lot.
Its what the forums is for. Feel free to ask any other questions. A lot of experienced peopld on these forums. I'm just an entry.
i`m thinking on something like this .And here is where i am asking if its posible?
In theory is the same as using a single coil for sub freq.
I wanna use a switching device to select freq. between lest say 100-200-300. (or someting like that).
could it work or should I use only 1 ?
The frec on whom the switch is switched to is in contact.and the others are off basically.
It's next to impossible to use a 6db passive crossover for a 100hz subwoofer. I guess you would get some results, although the inductor would be huge.
What impedance is the woofer?
They're not terribly huge, I've got a few sets of passive sub crossovers, my largest ones are 80hz lpf @12db/4ohm and the coil plus the caps are glued to a piece of wood that measures 5 inches by 6 inches or so, the coil itself is about an inch thick and maybe 5 inches long.
Air cores might be huge (and expensive) but the steel laminate most folks use aren't that big, see here:
ERSE - Super Q
inductor for a 4 ohm woofer
yes a inductor for a 4 ohm woofer wouldn't be bad e.g. 3.5mh - 6.5mh.
The roll off will be so gradual with a 6db slope, it will drive you crazy when trying to set it up. I'd at least go for a 12db, or if the expensive parts are free, go 24db.
Yes I looked it up.one coil for 6 db, and for exp 2 caps and a coil for 18 db.
I looked it up and saw it.
hmmm...by parts your refering to The simple coils and no other parts (like capacitors or resistences) no?
I thought if I just put a single coil on the + wire before the speaker it would have solved it.(at least thats what I saw from the schematics on the net..simple coil gives you freq of lets say 100 hz)
If I am mistaken please let me know.
A basic paint drawing if you got time would be helpfull .
It does, but it only gives you a 6db electrical slope, which would mean you'd still hear muffled vocals and stuff coming out of your sub.
Adding the parallel cap(s) to make it 12db electrical would be a great idea. It'll clean up the sound of the sub and will only be a few additional dollars depending on what grade of cap you choose. I've always used relatively inexpensive electrolytics in my sub crossovers and haven't had any trouble with them yet.
Yes I see....i`ll study up some models on the net and see what I can do.
Parts wi`ll be bought in the weekend days.thats the electric supply days .
I think i`ll go allong with the 12 db ones.If I can find the necessary parts i wi`ll try a minimum of 2 switches or a maximum of 3 deppending on the stuff found and bought.
If not I`ll stick with a single freq.
p.s.
the parts are bought at arround 0.35 cents the piece...capacitor, coils, etc.
lets hope I find the right ones.
Keep in touch and i`ll keep you posted with the construction.
