How does this driver handle as low as this frequency?
I found a vintage speaker pair has quite weird specification. They’re ADS L1590 speakers. Their specification shows they have woofer-to-midrange crossover point at 350Hz. However, the midrange used is merely 2-inch dome!
So, I don’t think this is the -3dB point of the dome midrange. Instead, it might be an actual crossing point between woofer and midrange, I don’t believe there are any 2-inch domes could handle that low frequency. Is my assumption correct?
If so, the next question is about the roll-off. The crossover schematic also shows the filters are second-order configuration on every section. The question is if the second-order high-pass filter was applied to that 2-inch mid-dome at -3dB point of its natural roll-off, the acoustically combined response of the mid-dome (high-pass section of the mid-dome) should be 24dB/octave instead of 12dB/octave (first 12dB from the filter and another 12dB from driver’s natural roll-off). Is my second assumption correct?
These speakers have two 10" bass drivers so I'm imagining there's the potential for these to get pretty loud.
350Hz is too low for even lots of 3" domes to work with low distortion.
The only way to find out specifics would be to measure things. Or simulate the crossover.
Reactions: presscot
