How To Build a HEXFred Bridge
Thanks for the fast reply...do you have any reccommendations on how to attach them...do they need a sizable heatsink to run at the reccommended current?? I'm thinking of bolting it to the main heatsinks with insulayting tabs of course...wonder how that might affect the sound...the output stage is also on the same heatsink...or do you recommend a seperate heatsink...for all my rectifiers???I will not probably be using a PCB for the rectifiers...just screwing them on and soldering straight...but I will mount them is a "star" like configuration...with 4 diodes...one on each side...Thanks for your help again...
I resently did a bridge with mur3060, only used one diode from each pack. Someone said paralleling made more switch noise, and since I was gonna use it for a aleph 3 i diden't need the extra curent capability any way, so what the heck... I bolted them to a L bar 3mm thick and 80mm by 30mm or so. l bar bolted to chassis. Temp at tab is 60 deg C or so.
Here's my pcb layout with snubbers:
I can also post eagel files or pdf for printing if you like to.
JasonL, I will probably not get them made pro, at least not at this time. Im planning to do some changes to make the pcb more versatile, so it accepts other diodes, (like mur860 etc) pcb mount heatsinks for smaller diodes and different sized caps and resistors. The present version was just adapted to whatever I had laying around.
The pcb files are to big to attach even when i zip'ed them and the forum want accept pdf, so you'll have to send me a mail if you want them. You have to have eagel 4.01 to open the pcb files.
li_gangyi said:
As above...I have some MUR3060WT HEXFreds...they are common cathode connected...how do I actually go about making a full wave bridge...do I have to waste a few internal diodes??
Why do you want to make a bridge? Do you already have the xformer? If not, chosing a xformer with mid-tap, you get away with just a single dual HexFRED device per voltage.
Jan Didden
