how to connect a sub to analogue system
I'm hoping someone can help me, I would like to connect a subwoofer to my audio system.
My system is analogue: t/tabel - SUT - phono stage - preamp - however amp - speakers.
I don't know how to connect it. Does it go into the power amp,; the pre amp ?? Do the speakers wires need to be connected differently?
Is it best to a passive sub or active?
I'd appreciate some help and direction.
Thx so much ,Bob
You need the subwoofer to have high level inputs, you then connect your speaker terminal posts to these inputs.
Keep your wires to the speakers as normal insert the extra wires into your banana plugs at the amplifier and run them to the high level inputs on the subwoofer amplifier.
Have a look at the BK Electric website all of their subwoofers can be connected this way.
https://www.bkelec.com/
Do the speakers wires need to be connected differently? Is it best to a passive sub or active?
Since you don't have the subwoofer yet, first decide which type to get.
An active subwoofer has an internal amplifier that connects to your preamp.
It also has a level control to match it to your system's acoustical output.
A passive subwoofer uses your existing amplifier, and has a crossover inside
that your speakers connect to, instead of directly to your amplifier.
Usually the active type will work out better for most systems.
That can be misleading.
Active sub woofer isn't indicative of having a built in internal amplifier. In this case I'm sure you meant "active" as an all-in-one self contained plug and play unit.
More often then not, and I think generally accepted the term active is used to describe a type of crossover network, for but not limited to subs. Active vs passive.
The last point you made would also depend on which way its looked at. For convenience then I would agree, its better for most systems. It meaning an all in one plug and play type sub woofer. For ultimate tuning and flexibility it is not better for most systems.
An active speaker has an amplifier built-in.
An active crossover is before the amplifiers.
You may have an active speaker with a passive crossover (some of the older Wharfedale PA speakers have this), or a passive speaker with an active crossover (ie, the crossover is external and needs amplifiers). You can also have a passive speaker with a passive crossover (most HiFi speakers), or an active speaker with an active crossover (pretty much all active studio monitors or PA speakers).
Chris
Biamping can be done with a subwoofer having dual voice coils. That is how I took damuffins meaning as. But I could be wrong?
I wouldn't consider a self powered sub biamping, but a secondary amp piggybacking on the signal of the mains amp, or first amp, or right from the main preamp.
I'm sort of thinking that a passive subwoofer with bi amping might be the way for me to go. REL was mentioned as 'musical' subwoofer.
Does anyone have any other suggestions for subwoofer brand/model. I consider my system as 'musical' with quite an organic kind of sound - I like sound that are closest to the sounds that orchestral instruments actually make. I'm looking for a slightly tighter and defined sound in the lower bass.
Bob
Bob
Yes look at the range of subs offered by BK Elecronics mentioned in my post earlier on they are good for music and very good prices as they sell direct.
