How to connect a wireless microphone receiver to a portable speaker aux input
Hi. I'm a bit clueless when it comes to audio connections, so forgive me.
I have a wireless microphone receiver for exercise instructions. It has an XLR balanced output, and a 1/4 inch jack unbalanced output. I think the outputs are mono since there is only one actual physical microphone.
I have a bluetooth rechargeable speaker, with an "aux" 3.5mm stero input.
I would like to use the speaker with the receiver.
I tried a guitar lead with a 1/4inch to 3.5mm mono converter. A multimeter showed electrical connectivity to be fine for these to. But there is no signal at all from the speaker.
I also have a twin 1.4 inch jack to single 3.5mm stero jack audio cable. If I connect one of the 1/4 inch jacks to the receiver, I do get microphone audio from the speaker. But this leaves the other 1/4 inch jack unconnected, so it's noisy. Plus, I suspect I am only driving one of the speaker's stereo channels this way.
What's the simplest way to connect the two? I'm not sure if I need a pre-amp or not. The manual for the receiver says it has an audio output of 150mv. I do have a powered "Sideman SM-3 Parametric Equalizer" unit I could use. I'm not sure if it is a pre-amp, but it does seem to give a lot of signal boost.
Thanks for any advice.
Mark
You will only need to use a pre-amp if the the portable speaker aux input is not adequately driven by the 150mV output of your receiver.
If you got sufficient loudness when using the twin 1/4" jack arrangement, you should be good to go using the lead I recommended.
It would be nice to know the input sensitivity of the aux input, if you have access to the portable speaker manual.
The manual for the speaker does not specify input sensitivity. It says signal to noise >=80dB but I think that’s not relevant. However the lead arrived and the loudness seems good, especially when I use the para eq box. Thanks for the help
