Hello, is there any specific mark, shape, color on these ceramic caps helping to determine them? Or how can I sure that a cap is not NP0/C0G type? Tolerance? Price?
Thanks.
Thanks.
No, there may be no indication whatsoever. Or, they may be printed with NP0 or C0G. Ideally you should know what you bought! If you put the cap on a capacitance meter and heat it up with a hot air gun, the NP0s will change very little. Any others will change value significantly.
size is a clue too - compare with known NP0/C0G of the same value, V rating
the "bad" high K ceramics are used to pack more C in smaller packages
Some C0G caps may have a black hat. A coloured hat is a sign that it is not C0G. No hat tells you nothing.
Good point. I just tested some of ceramics with soldering iron using my LCR meter. Many of them dropped their half capacitance even keeping soldering iron near in just ~5 seconds. Some bigger but small valued ones just drop about %3~5 even if I touch soldering iron to them! I may put some pics later.
You can find out for sure very quickly using a cap meter and a heat gun.
Yes I just find out. All replies in thread was very informative.
Thank you all.
- Design & Build
- Parts
- How to determine NP0/C0G capacitors?
