How to make a headset's microphone work in a USB Interface
Hello, I'm trying to make a headset's microphone work in a Lexicon Alpha but I'm failing miserably.
The headset has a TRRS 1/8 jack and comes with a splitter that is turns it into 2 TRS 1/8 jacks (Why the mic one is TRS and not a simply TS is beyond me.)
Either way, I tried using a TRS to TS 1/8 adapter so it's a mono signal and then that into a TS 1/4 jack and tried plugging it into the "Instrument input" in my Lexicon Alpha USB interface, but I don't see any input.
Is there something I'm missing?
The USB interface has the following inputs:
- Microphone Input: Female XLR Pin 2 Hot
Input Impedance: 600 Ohms balanced
GAIN: +50 dB
EIN: −115 dB A-weighted @ +50 dB gain (150 Ohm source impedance)
Maximum Input Level: –7 dBu
Frequency Response: +0, −0.5 dB 20 Hz - 20 kHz, ref. 1 kHz
THD+N: <.005%, 20 Hz - 20 kHz
- Line Inputs: (2) 1/4" TRS balanced or unbalanced
Input Impedance: 20 kOhm balanced, 10 kOhm unbalanced
Maximum Input Level: +13 dBu
Frequency Response: +0, −0.5 dB 20 Hz - 20 kHz, ref. 1kHz
THD+N: <.009% A/D, 20 Hz - 20 kHz
- Instrument Input: (1) 1/4" mono jack
Input Impedance: 1 MOhm unbalanced
Maximum Input Level: +8.5 dBu
Frequency Response: +0, −1 dB 20 Hz - 20 kHz, ref. 1 kHz
THD+N: <.0125% A/D
The headset's microphone probably requires a phantom supply that is very different from the ones used for professional microphones. It's usually a 2.2 kohm resistor to a supply voltage between 1 V and 10 V. See post 2 of this thread: https://www.diyaudio.com/forums/everything-else/352655-advice-weird-project.html#post6159191 (A phantom supply for professional microphones usually consists of two well-matched 6.8 kohm resistors to a 48 V +/- 4 V supply, one resistor for pin 2 and one resistor for pin 3.)
You say that normal TRRS inputs like the ones in a laptop (tried a Macbook) or a cellphone (Samsung S9), where this headset mic works ok, provide power to the microphone to work?
For further reference, the headset is a Cooler Master MH751, a common gaming headset.
Yes. The microphones are usually cheap electret condenser microphones with a built-in preamplifier (typically just a JFET connected as a common-source stage). The laptop / sound card / whatever needs to supply power to get the preamplifier to work.
Does your USB interface's microphone input have a 12 V or 48 V phantom supply for professional condenser microphones or none at all?
While it makes sense, i don't understand how the power is transmitted using the TRRS pins in a cell phone input, to me, one is ground, other 2 are for audio channel stereo output and the other is for the mono microphone input.
For this to work I'd expect another contact, how does it work?
