How to measure a collector voltage
Hello,
I am pretty new to measuring voltages. I have a SU-Z35 Technics amplifer with a SVI2004A IC installed, amp works fine with original IC, so it cant be my recap, re wiring work.
How to do i measure voltage of the Collector. I know its the middle pin? on the transistor, E is the emitter and B the Base. I use DC 500V on the multimeter and checked the voltages of the jumper pins.
Is it the same procedure, -ve on the case and +ve on the collector fire up amp, take reading turn off?
Thank you Sam
Yes, but the trick is to not short it to anything else. Often, it's best to use a component
that is connected to the collector as a test point instead.
VERY MUCH so.
Look at the back and find a resistor off that trace and clip on a "clippable" probe so that you don't slip.
I have damaged a few amplifiers by letting a probe slip and short two transistor leads. It does a lot of damage !
One never learns from one's mistakes.
One learns by getting it right, or being shown how to get it right.
VERY MUCH so. Look at the back and find a resistor off that trace and clip
on a "clippable" probe so that you don't slip. I have damaged a few amplifiers by letting a probe slip and
short two transistor leads. It does a lot of damage ! One never learns from one's mistakes.
Yes, TO-92 packages are almost impossible without special miniature probes.
The Collector voltage is taken between the Collector and Emitter.
For reference, have a look at this link;
Learn About Electronics - Fault Finding on Transistors
Thank you for the link and reply Jon. I am a bit confused about taking the voltage between collector and Emitter, so i take readings of both.
Thansk Ray, okay, so I was correct with negative probe on case and positive on the collector which I assume is the centre pin as E and B are printed either side of the transistor.
Thanks Andrew, i am very nervous about power. I can wedge bits of rigid plastic so the probe will not touch the metal of E and B, that way it should be safe, I hope
.................. Thansk Ray, okay, so I was correct with negative probe on case and positive on the collector which I assume is the centre pin as E and B are printed either side of the transistor.
2sa/c transistors have the Collector in the middle.
All the BC, Eline and 2N have the Base in the middle. Except a few "specials" like BCxxxL
