How to measure B+ current draw
Dear diy-ers,
I am looking for a method to measure the maximum B+ current draw for an amp with the power supply as shown below.
Could it be so simple as hooking it up to a dummy load and opening the brown wire and putting an ampere meter where the red circle is? After that we dime it and read the meter?
Thanks in advance
That is one of two paths the AC of the B+ follows. It is possible to calculate the correction for DC (I assume what you want). Except the correction is different for different types of meters (average, peak, RMS, dumb) It is a whole lot easier to break a DC point, as JMF sugests (altho that floats your meter at high voltage, which may not be necessary).
Put 1 ohm resistors in your power tube cathodes. Get the current in each and add, that's your power stage current. In guitar amps you rarely have 10% more in preampery, but you can measure voltage drop across resistors and do addition.
Reactions: AmpKiller66
If you are that afraid of this method, then wire a fuse holder in series with your meter and clip all that to the fuse holder.
Or just lift one side of the fuse if it's a snap in holder...
My meter is fused anyway... Or use a cheap meter - it'll blow like a fuse if there's a fault... I once blew the chip off of the PCB of a DMM when I had it set up for current but was checking 600VDC with it. Oops 🙂
