How to polish/clean faded perspex?
Joined 2009
Ive got an old boombox going again but the perspex on the dial is UV faded,can I polish it with something to bring it back to clear or does it fade right through the thickness of the perspex? The writing on it is on the inside,just as well if I can in fact polish it.
Comes to mind there are polishes for plastic, I would expect to find them at hardware stores or hobby and craft stores. But first thing I thought was automotive stores. Many cars these days have a clear plastic cover over the headlights, and it gets foggy with age. There are products specifically for polishing those up to restore clarity.
in the USA we have a duo of products made for plexiglass motorcycle fairings, etc...: meguiars plastic cleaner and plastic polish.
You could also try the various plastic 'headlight restoration' kits out there.
I have some powdered cerium oxide used for polishing mirrors that is likely the main ingredient in the items above. Works a treat.
Not both sides with the writing on the back. A standard
for polishing up plastic watch faces is metal polish, the
stuff more intended to remove the tarnish, buff metal,
but can it polish out the scratches in plastic surfaces.
rgds, sreten.
