Hi, I am haveing some problems with a hybrid amp, using some IRF610 mosfets, I suspect one is blown... how can I test it...?
I found some method with diode test on multimeter online, wich you charge up a pin and then take measurement over two other pins and then short all the pins with your finger wich makes the meter reading go high or not... sadly it didn't say wheather if it goes high the fet is dead or not....
One of the two fets I have in does go high, the other not. I have one spare.
Also, is there an easy test for lm317 regulators?
I added 3k3 gridstoppers as the smaller version was full of crap with my walwart.
I constructed a battery one.... made one that worked before... 🙁
Getting crazy voltages...
getting full 24V after CCS,
20V to heater filaments
erm, there are 2 lm317s in gain configuration each supposed to deliver about 150mA,,,
.I added 3k3 gridstoppers as the smaller version was full of crap with my walwart.
Short gate to source with a paperclip or something, measure resistance across drain-source and source-drain. It should be open circuit both ways but one way will show some conductivity depending on how much voltage your meter applies to determine resistance as it may make the body diode conduct.
If it's less than 100 ohms both ways it's blown. If you have been fiddling with it in your hands without the gate being shorted to source then the gate insulation is probably smashed by static on your hands.
lol i smashed it with a short from multimeter probe... the low voltage obviously makes for failures that down blow smoke and makes it harder to find the nipper.
the absolute maximum gate to source voltage of most FETs is between 15V to 20V.
The gate capacitance is the only load (there is no resistance load in a FET gate) any finger or tool on the gate has.
The potential on your finger or tool could be kV. That equals a dead FET.
Look up PASS or ESP for simple FET testing procedure.
An indicated short from D to S or S to D = dead FET
Big Power FETs have big gate capacitance. That capacitance allows a large charge to be absorbed and yet the final voltage can stay below the 20Vgs limit. This allows careless handling and surviving power FETs, small FETS will not let you away with any careless handling.
ok, made a jig with protoblock to short pin 1 and 3
new one from packet
Negative probe on S positive on D meter reading 1
Negative probe on D positive on S meter reading 695R
I assume this is ok
Will wait for feedback before removeing fets from pcb to test in jig.
new one from packet
I assume this is ok
To measure an Nch MOSFET:
1) Use DVM in diode test position
2) Holding red lead on S
3) Put put black lead on D. Reading should be between 500 and 800, you are measuring the forward voltage drop in the body diode.
4) Put black lead on G. Reading should be 1... (open circuit)
5) Hold black lead on S
6) Put red lead on D. You shuld read 1... (open circuit) as the gate should be retaining negative charge from step 4.
7) Put red lead on G, you should read 1... (open circuit)
8) Put red lead backon D, you should read a low value (close to zero initially, possibly rising very slowly). You are now measuring the D-S voltage drop with the gate positively charged in step 7.
In any case, source to gate and drain to gate should alsways read open circuit. If you get low readings in steps 4 or 7, it's dead for sure (in either case, not a MOSFET... any more 🙂 ). If you get low readings in step 3 or 6, there is a good chance it's dead but you can test this later on, by doing it again with G and S shorted. If you get anything but the body diode reading in this case, the FET is dead. Also, you can try to measure the drop between shorted D+G and S, you will get the gate treshold voltage for very small Id provided by the DVM - however, most DVMs don't provide a high enough voltage to get over the gate treshold of VMOS, so you are likely to still measure 1... (open circuit), the exception being lateral MOS (will emasure low, about 1V, useful for testing for fakes), and PI-MOS such as the Toshiba Audio MOSFETs which will measure about 1-2V dependant on DVM.
BTW that schematic for a phones amp cannot work right as the required heater current for the 6922 is 300mA, and the current source connected LM317 only gives 150. It appears to me this was originally designed for a ECC81/82/83 12AU/AX/AT7 type tube with center tapped 12V filament, which is divisible into two 6.3V 150mA filaments by grounding the center tap - but then you have a problem with the too low anode voltage.
Ili there are two of the 150ma sources tied to the heater filament, only one channel shown in schematic...
As i said i build a workig one before....
Hi Nordic
Before putting the Mos Fet in circuit , make sure that the connection node of the CCS , the anode of the valve and the 220 Ohms resistor , is at ~ half the rail supply voltage.
Only if that voltage is right , connect the Mos Fet in circuit.
MOSFET Tester Circuit Matching Power MOSFET
How to test mosfet?
I guess you missed some of my posts ..
I know you often read them. So must be a rare exception 😀
I have my suggestions.
Circuits I use for testing JFET and MOSFET.
I want as good P R E C I S I O N as I can get .. I am a bit of freak, I guess.
But when it comes to fantastic precision instrument and circuits at our forum
... nobody can beat dear jackinnj.
😎 He has made sure to get the best and build the rest!😎
See for example:
Heat Sink Tester - jackinnj
DIY Test Equipment for Audio - jackinnj
I happen to know jackinnj use a lot of MOSFET.
He also does MOSFET Matching and offer them for DIYers to buy to a good price!!!!
So, if anybody can tell us how to Test MOSFETs ... it is this man.
Jackiinj HOMEPAGE - [url]http://tech-diy.com/[/URL]
A visit here may give you some hints and I hope jackinnj read this topic
and contribute some of his knowledge.
Here I will contribute and post 😎 my way of doing FET testing / matching 😎
I post my MOSFET tester circuit.
It is not very difficult to build.
A dual regulated supply with Heatsinks - ADJUSTABLE with potentiometer
... LM317 LM337, will give you possibility to to Tests up to 1.0 - 1.5 Ampere.
This would be enough to get good values.
Lineup Audio Lab
lineup
How to test mosfet?
See for example:
Lineup Audio Lab
lineup
Nordic said:ok, made a jig with protoblock to short pin 1 and 3
new one from packet
I assume this is ok
That sounds ok as long as the '1' is just the meter indication of over-range rather than 1 ohm...
This is an image
of this Korea built Multi Hybrid Head Phone Amplifier
I give the link below this picture ... 😎
http://www.headphoneamp.co.kr/bbs/zboard.php?id=diy_sijosae
lineup
lineup
thanks for all the tips, on resoldering everything, and powering up the wallfart farted out, so I have to make a psu now... suppose I could piggyback 2 12V regs to get 24V the way a pic programmer uses 2 small regs to create combined voltage?
Lol Guess I should just have left it when I got it to work the first time... certainly the best sounding headphone amp I build so far.... damn, wasted like a week on this one... so many other designs to build, so much to learn...
This is only the second time I use Fets, the other was the Pedja Rogic buffer, which thankfully worked seamlessly...
Actualy all the mosfets seem to test ok... :x
I always try not to touch pins of components needlessly, and try to remember to discharge myself on a nut in my PC case when working with anything I suspect to be sensitive.
I will remove the fets until I can get the right voltages as tubeguy suggested, on the CSS
so Nordic
you do not think my mosfet tester is any good
in fact i know the opposite: it works very good!
okay, i wont post any more circuit ... in this topic
We are still in COLDEST and DARKEST time of year
here up north
you have seen my pictures of The first Snow .. remember?
But right now, outside my window pane,
only 1.2 meter from my keyboard
is
-22.6 C degrees cold
In middle of night is often close to -30.0 C
**** note ****************
-22.6 Celsius = -8.68 degree Fahrenheit
-30.0 Celsius = -22 degree Fahrenheit
here up north
is
From Wikipedia, the free encyclopedia
Anders Celsius
Anders Celsius (November 27, 1701 – April 25, 1744) was a Swedish astronomer.
Celsius was born in Uppsala in Sweden.
He was professor of astronomy at Uppsala University from 1730 to 1744,
but traveled from 1732 to 1735 visiting notable observatories in Germany, Italy and France.
At Nuremberg in 1733 he published a collection of 316 observations of the aurora borealis
made by himself and others over the period 1716-1732.
In Paris he advocated the measurement of an arc of the meridian in Lapland,
and in 1736 took part in the expedition organized for that purpose by the French Academy of Sciences.
Celsius founded the Uppsala Astronomical Observatory in 1741,
and in 1742 he proposed the Celsius temperature scale
in a paper to the Royal Swedish Academy of Sciences.
His thermometer had 0 for the boiling point of water and 100 for the freezing point.
The scale was reversed by Carolus Linnaeus in 1745,
to how it is today.
No, I didn't say anything about your tester.. looks like a good idea, but a little advanced for the basic functionality testing I wanted, sorry if I didn't thank you specificaly, you should know how it gets when these things frustrate us. Lol my arthritis would make my whole body sease up in that cold, guess you could build a class a seat to heat your bum.
By this anode voltage are transfer curves inflexed like turkey sabre...it give really sweet sound....😀
Upupa Epops said:turkey sabre
Pavels personal translator enters:
Turkish sable aka sword.
(called: Samur in Turkish)
- How to test mosfet?
