How to use subwoofer apart from speaker? Logitech X-230
I have a Logitech X-230 system, I don't want to use the X-230 sound system speakers because my laptop speakers are of better quality, I just want to use the Subwoofer. But the problem occurs here. Because using the subwoofer system to use with its own speakers. So it doesn't work alone. I drew the program of the system. More or less, if my hand holds a soldering iron and a tool, it can be seen if it can be explained. I did not cancel these speakers. I want to connect the subwoofer to the laptop and use it only as bass, how can I see it or is it possible? I am sending the subwoofer's circuit and system diagram attached.
Forgive me if my english is bad because i am not a british or american citizen 🙁....
Can you just remove the speakers by clipping and bypassing the speaker wires to the two satellites? You may not need to bypass them; maybe just take the speakers out of the system by clipping the wires to them. As long as the input doesn't need the speakers' positive and negative points, you should be good. Can you provide a diagram of the inside of the speaker you have drawn in the middle? If you have an ohm meter, you can find out which go pins the 3.5 mm jack connects to on the 9-pin plug. Once you know that, you can remove everything and reconnect the input jack to the appropriate pins
