Hypex Active Home 2-way amps
I bought a couple of these amps directly from Hypex in The Netherlands a while back for testing for a potential project. The project never got off the ground, and the amps were never used. I have two. One has been opened but unused, the other is unopened.
Specs:
2x80W/4Ohm
120W max. total power
Linkwitz-Riley
Make me an offer on one or both. I paid around $150 for each new. Thanks!
kestrel200 said:
So do these come with the crossover "modules" if so waht are they?
Not having any experience in this, I'm not entirely sure what I'm looking for, but there is a module on the amp labeled "2500 Hz" marked "Filter High/Mid" on the circuit board, which I think is what you may be referring to.
