Hi there,
Since monitor prices are quite high and the price difference between 15" and 17" is almost non-existant I finally decided for a Hyundai L70S ImageQuest 17" Monitor. It was quite easy to strip and the only read difficulty was to remove the outer plastic case. I eventually used a knive all along the edge of the front and back plastic pices and they separated. After that it was an easy process just dismanteling all the various components.
The lcd screen itself is actually a Samsung (sorry I don't have the details right now). There is only one board attached on the horizontal axis. There is also a very good connector/cable between the panel and the driver board. This makes it very easy to move and put back together again.
Overall its very easy to dismantle and the specification for this screen are quite good. The screen is to big for my ohp but I figured that even if I can currently only use 15" of it's size it will still offer better resolution then a normal 15" xga panel.
I will eventually source a larger fresnel so that I can use the full 1280*1024 resolution.
I can post pictures of the dismantled screen if somebody wants them.
One question: After dismantling the screen I found several layers of transparent sheets. I guess its for the backlight. I tested the screen without them and I got a picture on the wall. The question is should I use any of the plastic sheets to improve picture?
Kosta
Specifications:
LCD Size 17 inch(17 inch viewable)
Type A-Si TFT Active Matrix
Viewable Angle +75/-75(Left/Right) , +55/-70(Up/Bottom)
Pixel Pitch 0.264 mm (H x V)
Contrast Ratio 450 : 1 (Typical)
Luminance 260 cd/§³ (Typical)
Input Signal Video R.G.B Analog(0.7 Vpp)
Sync H/V - Separate / TMDS Signal
Connector 15 pin D-sub
Scanning Frequency Horizontal 31k 80 kHz
Vertical 56 75 Hz
Resolution Max 1280 x 1024 @ 75Hz
Recommended 1280 x 1024 @ 60Hz
Active Display Size (H x V) 337 x 270 mm
Display Color 16.7 Mil
Response time 16ms
Kosta
Specifications:
Vertical 56 75 Hz
Response time 16ms
nice job! can you post pictures of images. I am contemplating on building an excellent projector with 10ft image for my soon to be made home theater. thanks.
yeah definatley post the pics.
i want to know how to project the full 17"
if you can project sxga res then you can get full HD Wide screen
can you get sxga 15" lcds
hi again,
I have the pictures in my digital camera but I had some problems with my computer and I therefore have to fix it and then reinstalling the camera drivers.
I will try posting pictures this weekend.
Exipos
Exipos
Any update on the pics? Now that Im finally working, Im thinking of making my 15" back into a montor and stripping a 17".
sorry guys. In my quest to make the projector work with the large fresnels from diy labs I forgot to post pictures. I am now on vacation away from home so I will not be able to for the next 3 weeks. I will post when I'm back.
Exipnos
Exipnos
- General Interest
- Everything Else
- The Moving Image
- LCD
- Hyundai L70S 17" is usable
