Hello,
not quite satisfied with the sound of my Pro-Ject Phono Box SE preamp, I started to improve it and would like to have your opinion about what I have done and what can still be improved.
This preamp is dual mono with 3 op amps per channel. It works between a Pro-Ject 1-Xpression turntable (with 2M blue cartridge) and a Nad C326BEE amp.
I started by replacing some PSU capacitors.
Then I swaped the four NJM 4580 op amps for dual OPA 627, and the two TL071 for AD797 (replacing these two was a HUGE improvement).
I don't have the doc, so I tried to draw it but as I am not very experimented with electronics I coudn't quite understand the circuit. Here it is anyway, I'm very sorry if it is badly drawn and incomplet, this is all I managed to track with my eyes and my multimeter...
Power Supply stage :
RIAA Preamp stage :
Is there anything obvious you see could be done to improve it further?
Or is it a bad architecture and I should directly buy something more serious?
I'm thinking maybe going to a tube preamp like the Yaqin MS-23B or the Douk audio Little Bear.
Thanks anyway for your help.
RIAA Preamp stage :
