infinity SUB-100 junior II
Hi
i have a problem with transformer for infinity SUB-100 junior II
It is a plate active sub-amp (around 120w rms)
transformer is start failing, Overheating (burned Thermal Fuse)
i will order new toroid transformer version, But i don't know how many Ampers i need to run this amplate properly.
manufacter doesnt put marking for Transformer....
i replace termal fuse, and make measuring on output:
2x34,33V and 2x17,15V (without load)
This may help:
http://4.bp.blogspot.com/-Y7C4xBv54cY/VHqb0ECW37I/AAAAAAABGY0/73ACa6ig1uQ/s1600/oiwer+amp.jpg
http://2.bp.blogspot.com/-S1Y3STCdZuk/VHqcOSOamtI/AAAAAAABGY8/4_8N2_DvQUw/s1600/pre-amp.jpg
http://diagramas.diagramasde.com/audio/ATX 100 SUB service manual.pdf
So i basicaly need 2x35V and 2x18V ?? (what about Amps??)
Keruskerfuerst thanks for guide. I Fixed The problem 🙂
I ordered 200VA Toroidal Transformer
2x35 V – 2A
2x18V – 0,5 A
work perfectly
IMGDEAD]
IMGDEAD]
