Innovatek 7.5 monitor
Hi guys, I've gone and ordered a Innovatek L7M 7.2" STN LCD MONITOR from mp3store.com and i was just wondering if this is a good monitor for a projector before i take it apart, If anyones used this monitor before what was the results.
Specification
* Screen Size: 7.2 inch(Diagonal length)
* Display Method: Active matrix system
* System: NTSC
* Resolution: 960x234 dots
* Built-in Speaker
* Back light: Cold cathode filament tube
* Contrast: 88:1
* Power supply: DC12V
* Power consumption: 7W(Max.)
http://www.mp3playerstore.com/stuff_you_need/special/L7M.htm
Innovatek
I have the IN007VG and the quality is amazing. Accepts VGA in and does 480P. It is a rebagged Liliiput VGA. Came out to $235 CDN shipped. The screen you bought seems like a good starter screen - but it has a low dot count. The image will not be as sharp. You may want to reconsider and replace it with the 007VG before they ship yours out. Just remember you are going to be projecting this image so you would like to have the best image possible. However you will be paying nearly twice as much! :xeye:
