Hi all,
I seeing IRF3205 is going obsolete every where. What will be the best replacement for it to use with 47ohm as gate resistors.
I use to depend on these on many amps. Thank you.
They appear to have a long lead time but I didn't see that they were obsolete.
Check the following for distributors.
IRF3205PBF Infineon - MOSFETs - Distributors, Price Comparison, and Datasheets | Octopart component search
check the link for replacements. I have used this site many a times and find that the replacements they give here work very well.
IRF3205 MOSFET complementary, equivalent, replacement, pinout, specs, dimension, characteristics
Farnell have these in stock at least in the uk
https://uk.farnell.com/c/semiconductors-discretes/fets/single-mosfets?st=IRF3205
They’re not EOL , just on long term back order like a lot of other devices currently
So get them when you see them
