Is H945P the same as 2SC945?
I have a bunch of H945P transistors in my active PC speakers. The system died on me some time ago and I want to see if I can repair it.
I can't seem to find anything on this particular transistor so I'm not sure if the 2SC945 is the equivalent.
If some of you more experienced people can help me out here?
I don't have the answer, but I would suggest that the case style of the part tells you a lot...a 2SC945 is a simple, small TO-92 transistor that is rated at 60V, 100mA, and 250mW. Now, if this H945P looks like a TO-220 power transistor (for instance), you KNOW that they aren't equivalent.
Thanks guys.
It is indeed a TO-92 device EchoWars.
Thanks for pointing me towards the datasheet Jacco.
Problem now is to find a supplier who has these little buggers available. Farnell, RS, Conrad, Mouser and Digi-Key don't have them.
