Is there a single 5.1 full range plate amp in existence?
I don't think I've seen a 5.1 plate amp (though there's no technical reason why one couldn't exist). You can find Class D amplifier boards with 6 channels or more if you wanted to go even more DIY.
For a practical setup there's a few reasons I don't think it would be a great idea though. Receivers that do 5.1 sound have a lot of settings that are necessary to properly set up the system, including delays per channel, gain per channel, EQ, and various other DSP settings. You're not going to find a plate amp that can do those settings.
Here's a 6-channel plate amp that can be configured as 5.1, although with the current software it is 2.2 (stereo tweeter-woofer plus two subwoofers).
It's even got WiFi input
And a cell phone app to control the DSP!
This is getting written up as a PE project on their Project Showcase--should be submitted in about two weeks
One question, where does the 5.1 come from. You need a decoder which is in the receiver.normally. Not seen a TV with decoded 5.1 outputs and even if your (say) bluray can output lpcm you need an HDMI licensed product to extract it.
All in all a reciever of HTPC seems a must?
I'll make it simple, Like a 2.1 plate amp, but instead has the parts to receive 5.1 surround sound, and a panel mount IR receiver mounted upfront + panel mount volume knob, and some more amp chips to power the extra 3 speakers. (Or 5, or 7 with dolby atmos capability, or 9 for dolby atmos and 7.1 surround sound?)
