Has anybody done this exact one from China? How does it sound?
LM3886 Power Amplifier Board Kit DC SERVO 5534 Independent op amp DIY Amplifier | eBay
Any other suggestions for best possible sound? Open to any kind of chip.
None,
I have never seen any chipamp layout that meets an excellent layout standard.
There are two PCBs that are excellent, but because the Member has turned this Forum into an income generator, they are both very expensive. And he is not prepared to release any IP that might reduce his income flow.
Lools good to my novice eyes. Was going to buy the same kit on Aliexpress but realized thry dont accept paypal. Thanks for the link.Has anybody done this exact one from China? How does it sound?
So do I need one for each channel?
Which toroidal transformer should I get if I buy two boards. Also im in Australia so we are 230v-240v.
What else can I buy other than a case? I messaged the seller to try and get a schematic.
Thanks lads!
eBay http://www.ebay.com/itm/272386340702
Thanks lads!
None,
here is a lot of members which turned into business - but what is business, I dont think they earn milions ... if somebody will, he can find a lot of things freee for diy ... if somebody will rather pay, he can do it here or ebay or somewhere ...
Audiosector? I don't agree with the "expensive" part if they are indeed "excellent".
He's referring to member tomchr, his business name is Neurochrome.com. His line of LM3886 based amps are the "Modulus-86" composite amplifier, "Modulus-286" composite parallel 3886 amp, and the "LM3886 Done Right" a straight up plain 3886 with no composite opamp babysitter. They are all excellent designs, with excellent sound quality and he provides excellent instructions and support. You get what you pay for.
fructose, dont build LM3886, rather build or find something with LM4702 ...
Cool. Got suggestions for a LM4702 build?
Nover capacitors are not British.
Nover is part of the Anglia Group, a British company, according to their website.
amazon, ebay
I sent you PM with links ...
National Semiconductor used to have designs of amplifier circuits that their engineers designed around their chips. Any of their designs were very hard to beat and worked like a dream. My LM4702 amp has been absolutely reliable and will give nearly any Solid State amp a fair run for the money. I've had it for about 15 years with absolutely zero problems. I wish all audio equipment was as reliable!
BTW, I've brought that amp to many audio meets and have experienced no complaints about the sound and it's been left in play for hours...
Best Regards,
TerryO
Beware that TI discontinued a wide range of audio ICs about two years ago. Sadly, the LM4702, LM4780, LM3875, LM3876, LME498xx, and some other LME family members were all among them. The LM3886 is still in current production. The LM1875 is as well.
That aside, I second Terry's suggestion to go through the National Semiconductor (now TI) application notes for your chip of choice. If you haven't already, I also suggest reading through my Taming the LM3886 article series. While some of the content is specific to the LM3886, most of it applies to any chip amp.
Thank you for your vote of confidence and your review. I really appreciate it.
Tom
Tom
I've written to the seller, asking for a schematic. No reply yet. Anyone else get one?Has anybody done this exact one from China? How does it sound?
not good, additional opamps in signal way (servo and another one probably before LM4702 input) ... if you avoid these opamps, it can be good ... avoid I mean servo not used and another one jumpered if it is in signal way for LM4702
before you avoid servo, be sure your source have small DC offset ..
- Chip Amps
- Is this a good LM3886 Kit?
