ITT TCA350Z BBD delay datasheet
ITT TCA350X BBD delay datasheet
Hi, I purchased a couple of vintage TCA350X analog delay lines using BBD, these are dip14 chips. Im having trouble locating the datasheet. The only thing I could find is the datasheet for the TCA350Y which is a DIP8 part http://www.introni.it/pdf/ITT%20-%20Integrated%20Circuits%20for%20Consumer%20Applications%201977_1978.pdf. Im guessing that the TCA350X is a dual version of the TCA350Y, but I need to know the pinout. In that same document theres a TCA380, which is a similar part and has 12pins.
Does anyone has the datasheet for the 350X? at least I would like to know the pin-out, that should be enough.
