JBL experts please help. I have a set of JBL 127h-1s that I'm going to build 2-way speakers around. I see on the chart that JBL made 127H, 127H-2, 127H-3 and 127H-4 10" woofers. I don't see 127H-1s on this chart? The woofers have black frames and are stamped 127H-1 with white paint from the factory.
I'm no speaker design genius so I was going use the same tweeters and start with the crossover design that JBL used in there MB410s that have 127H-4s. Are the 127H-1 and 127H-4s similar enough or is there a better JBL two way speaker to imitate for my project?
Thanks for any and all input.
Used in the 4410.
Measured specs from back in early 1986, posted on Lansing Heritage forum, so this far forward YMMV/FWIW, but obviously better than nothing 😉:
Fs = 31 Hz
Z max @ Fs = 138 ohms
R1 = 29 ohms
F1 = 23.5 Hz
F2 = 42 Hz
Qts = .357
Qms = 8.077
Qes = .3735
Fsb = 75.4 Hz
Z max @ Fsb = 120 ohms
R1b = 27 ohms
F1b = 66 Hz
F2b = 85
Vb = .8 cu ft
No = .87%
SPL = 91.58 dB
Cms = 6.8E-4 M/N
Mms = 38g
Bl = 11.07
Le = .76 mH
Re = 6.1 ohms
Vas = 4.0 cu ft
Fs = 31 Hz
R1 = 29 ohms
F1 = 23.5 Hz
F2 = 42 Hz
Qts = .357
Qms = 8.077
Qes = .3735
Fsb = 75.4 Hz
R1b = 27 ohms
F1b = 66 Hz
F2b = 85
Vb = .8 cu ft
No = .87%
SPL = 91.58 dB
Cms = 6.8E-4 M/N
Mms = 38g
Bl = 11.07
Le = .76 mH
Re = 6.1 ohms
Vas = 4.0 cu ft
