JBL 2342 Horn, Dimensions wanted
Hi everybody
I am looking for the dimensions of the JBL 2342 Horn. The 2344 is available on several sources, but not the 2342. I would just need the front part (the butt cheeks) measures. The idea is to build a 4425 like cabinet with the small bi radial horn. I would then model the horn in 3D for either milling in wood or for 3d printing.
Most important would be the outer dimensions, the height of the radial part and the dimensions of the slot in the middle. As the back part is easy there is no need to unmount the speaker if somebody would be nice enough to measure a 4425...
Best regards
Christoph
Recollecting that the 2342 horn was also used in the 3678 cinema speaker (besides the 4425 monitor), here is the official CAD file from JBL themselves in DXF (Autodesk) format***. I doubt if things can get any more authentic than this. You may simply ignore the enclosure/LF and the compression driver to focus on your element of interest.
*** Rename file to *.DXF after downloading. Enjoy!!
  • Thank You
Reactions: camplo and GM
