JBL control 26CT ceiling horn/coax speakers and 19CST subs
I have a few (10) JBL ceiling speakers models 26CT coaxes with conical horn on a tweeter and 3 subwoofers model 19CST. They are equipped with line transformers but satelites are 16 Ohm /90dB without transformer and a nice match for tube amps I'd guess, and subwoofers are 8 Ohm. Overal in nice condition for used speakers. They are quite expensive new at ~$300 a pair for satelites and ~$500 for a pair of woofers. I will sell 26CT for $50 each and 19CST for $90 each (one with cracked but still OK looking ceiling trim for $70). All mounting brackets will be supplied .
Specs can be found here http://www.jblpro.com/pages/install/JBL.Ctrl26C.pdf
and here http://www.jblproservice.com/pdf/Control Contractors Ceiling Series/Control 19CST.pdf
Bump and I post it on E-bay I think as I'm running out of space. For resorceful individuals it could be an opportunity for a cheap SET friendly setup. Matching transformers included with those speakers could be used as an output for parafeed SE amps , I'd think one kt88 for woofer and el84 for satelite would be all required. Satelites are 16 Ohms 6" coated paper woofer and conical horn loaded titanium dome. Specs are on JBL site. Thanks
