jl audio slash 1000.1 powers up plays a few then switches blue light low voltage.
My jl audio slash 1000 is acting up.
The amp plays for a minute or two until i start to go up in volume then it would cut out and switch to blue low voltage light.
I used the amp for years without issue.
I managed to test the voltage at the amp terminals while it was playing & cutting out.
Voltage measured 13.35 then zap blue light.
I realized right before cut out the amp will sound some what wierd like its losing power then zap blue light.
Please help.
No smoke or funny smell or overheating from the amp either.
No i do not own a scope.
I own a multitmeter.
I decided to remove the amplifier to inspect further and realized on the power connection end the ground connection socket is somewhat melted & scorched.
Any ideas??
I'm using recommended 4 gauge power wire.
If those terminals show signs of overheating, the voltage could be dropping there. They can be resoldered but melted plastic around the terminals can make it somewhat difficult. IT also takes a relatively powerful soldering iron to do properly.
Are you using pure copper wire or is it CCA?
No its not melted.Although i took off the backplate to take a closer look.
It seems the ground middle terminal has a hairline crack on the solder joint to the board.
It was kinda hard to spot coz the control panel daughter board was in the sight of clear view.
