JL Audio subwoofer 2 or 1
Not sure if it makes any difference but...check out my drawing.
Run 2 JL Audio 8w1 at 100 watts each or run 1 JL Audio 8w3 at 200 watts?😕
Not sure if surface area, build quality or power has any correlation here....let me know if any of you have tested this out before. Meaning running 1 8 inch sub with twice the power or 2 subs half the power.
4 door soft top jeep wrangler. Subs most likely won't make any difference when the top is down.
Let me know if you need more info!🙂
I assume those models are the same size.
You'd need 400W and twice the excursion in order to get the same SPL from one speaker.
With two drivers, I think you can lower the space required for one driver in half, if you use an isobaric configuration (or in a tapped horn).
