Here is a new GB for the Joachim Gerhard Buffer Filter.
The orginal schematics can be found here :
http://www.diyaudio.com/forums/digi...ng-new-ess-vout-dac-es9022-7.html#post2867664
The prototype is shown here :
http://www.diyaudio.com/forums/digi...ng-new-ess-vout-dac-es9022-8.html#post3040691
Details of the offer :
http://www.diyaudio.com/forums/digi...g-new-ess-vout-dac-es9022-10.html#post3101883
Please add you name, continent, and quantity required as below :
Shaman 1x EU
MisterRogers 1x ??
jean-paul 1x EU
unixdeveloper 1x USA.
Patrick
Shaman 1x EU
MisterRogers 1x ??
jean-paul 1x EU
Patrick
Shaman 1x EU
MisterRogers 1x ??
jean-paul 1x EU
buzzforb 2x USA
Patrick
> As I understand, those buffers suit only V-Out DAC chips. Is it correct?
Can also be used after the IV circuit, e.g.
http://www.diyaudio.com/forums/digi...-sen-evolution-minimalistic-iv-converter.html
> Are those buffers intended for Single Ended DAC chips?
Each PCB is meant for 2 channels of single ended, or one channel of balanced.
So you would need 2 boards for stereo balanced.
Patrick
Patrick
Patrick
Thanks, Patrick.
Just to be clear, is the Joachim Gerhard Filter Buffer an evolvement if the Sen/Sen I/V?
Can the Joachim Gerhard Filter Buffer be operated on batteries, or conventional PSU, or both?
Will there be an option to wire the Buffer for Current Output DAC Chips?
It evolved round my ES9022 / WM8804 modules that Joachim had.
Please read the thread linked in post #1 for details.
Both.
No.
Patrick
Both.
No.
Patrick
- Group Buys
- Joachim Gerhard Filter Buffer for ES9022
