JVC RC-m90 cassette transport issue
Hi, I got an nice JVC RC-90M Boombox with an issue with the cassette transport, when I turn it on, all I hear and see is the solenoid momentary going up and down. Nothing else working when I press Play, ff or rewind, the belts are all fine. Not sure if the capstan motor should be spinning all the time on this? I checked on pin 5 of IC701 when i press play it changes from 5V to 0V, so the play switch is working. Pin 18 = 5V as expected. I noticed on the output pin 14 when play is pressed, the voltage stays around 0.7V (no change when pressed or released) I also checked resistance between pin 4 and 8 / 9 and with cassette out it is 1.4kohm and in 7.55kohm so the micro switch that detects the cassette seems ok I think. I checked all the electrolytic caps and all ESR / capacity measure fine. Checked all diodes, and transistors (removed out of circuit) all seem fine. Fr702 =1425ohms, Fr703 = 4.47ohms, fr701= 5.31ohms, (need to confirm these are correct) I also temporarily disconnected pin 11 (power off reset) from the chip, but no change. Could this be a faulty (JVC VUC0002) IC701 chip? Any other suggestions what to check ? I see the photo diode led on. Hoping someone has had the same issue and that there might be a common "known fault" with these transports
These are the voltages relative to ground on IC701, with cassette inside.
Pin1= Confirmed connected to ground with continuity meter.
Pin2=5.22
pin3=5.23
pin4=5.23
pin5=5.23
pin6=0.02
pin7=0.02
pin9=5.23
pin10=0.70
pin11=5.26
pin12=0.02
pin13=0.02
pin14=0.02
pin15=1.8
pin16=3.76
pin17=0.01
pin18=5.28
Anyone experience with these ? Thanks in advance.
One more observation today, when measuring the DC input on the capstan motor I have 12.3V on both the orange and white wires, when I remove both wires, relative to ground I measure red=12.3V and white 1.6V, but when connected again both meaure 12.3V, i tested the motor with external 12V DC and it spins fine, when I activate the solenoid the head goes up as expected.
I am beginning to think it is my jvc VUC0002 IC701 as The input voltage to the chip changes when I press the corresponding controls, but the output does not change, unless one of the logic protection circuits is preventing it, there are 4 X m74ls005 logic gates with!! a fairly complicated circuit. These are available and might just order 4, the VUC0002 is as rare as a hen's tooth
