Kicker kx300.2 IRFZ46N sub
Got a KX300.2. Blown channel. TIP35c and 36c replaced. The 3 FET IRFZ46N's i want to replace. I know definitely 2 are bad. ALL I have are IRFZ44N's. Is that acceptable? I might have IRFZ46 (no N) somewhere but can't find. 44's ought to be ok?
http://www.irf.com/product-info/datasheets/data/irfz44n.pdf
http://www.irf.com/product-info/datasheets/data/irfz46n.pdf
http://www.weisd.com/store2/NTE2975.pdf
For testing purposes should be ok, but I would source the IRFZ46N or the NTE2975 for a more reliable fix. If you use the IFFZ44N's you will won't to lower the gate resistor value's and replace all 6 mosfets with same, which should be done anyway.
Below is a link to Digikey for the IRFZ46N's
FETs - Single | Discrete Semiconductor Products | DigiKey
